Izento wrote:From my understanding, the clutch doesn't change even if you get a different transmission. You still will need a CA clutch if you get a KA transmission. This is because the bellhousing will always have to be a CA bellhousing. You can't put a KA transmission on a CA engine without using a CA bellhousing.
Now, all that aside, you can use a KA clutch on a CA engine (regardless if its the original CA transmission or a KA transmission with a bellhousing swap), but it requires removing some pin or something on the pressure plate or some s***. I just bought a CA clutch and called it a day.
I also have bleed problems with mine as well (luckily it isn't severe). These cars are famous for the stupid clutch system.
So can someone confirm that the clutch with the model number NSD035U is a ka clutch?
And sweet you say it exactly how everyone else explains it so I figure its a no brainer really. Just replacing gaskets would be the only thing that makes this annoying. But im getting under the car Saturday hopefully, Ill try what you guys are suggesting then! But thank you guys for the help!
edit: I hope autozone still has the ca clutch I returned! would a ca18de clutch work. I ordered it saying it was for a pulsar nx se.
