NiX »
https://forums.nicoclub.com/nix-u102894.html
Wed Oct 15, 2008 5:15 am
I have an intake manifold leak, so I started to take engine apart following the steps in the chiltons manual, but it wasn't very desciptive and I found three different sections where it says how to do it yet all varied quite a bit. I realized I wasn't going to finish the job before needing the car again, so I put it all back together. Upon start up the car ran but died right away with a hissing sound. I deducted the leak down to the rubber grommets that the fuel injectors rest on. First time I installed the rail I did not use the plastic spacers so I think the injectors went further down and probably messed up the grommets. I reinstalled the rail without the spacers again and it allows the car to start and run (with a very low and rough idle) I tried to find a replacement but autozone and another local shop didn't have them in their system. I really need to replace these because the engine stalls now instead of just having a bad idle.
Is this a dealer only part? Can it be bought by itself?
