Need G50 spring info....Please help
pdqwrx
Car: 1989 240 SX, 2002 WRX Wagon, 2003 FORD f150 4DR
Does anybody here have access to the stock spring rates for the 1990-96 Q. I am curios if the T has stiffer springs but more importantly, I am looking to compare them to the JIC coilocers I am now looking at. They are 10Kg and 8 Kg F/R. Any help is appreciated.
Also, anybody want to buy some brand new Tokicos with either 300TT springs or Stock Springs? or Just the tokicos. They may be for sale pretty quick.
ThanksScott
Q45tech
90-96 Qfront .......146 lb/in per the FSM ......Eibach fronts ~~ 164rear ........123 lb/in Eibach rear 130->200 variable
RobertsnewQ
PM me about the Tokicos.
pdqwrx
OK so I suck at math---What is the conversion from the KG to Pounds per inch. I looked on line and used a multiplication factor and went from 10Kg to 66 Pounds per square in. I suck at math-Please help.
DAEDALUS
Car: 1990 Infiniti Q45
Roughly 2.2 lbs = 1 kg. Your original units don't have a length. 10kg is not meaningful as a spring constant without a length to go with it. Maybe 10kg/cm? That would be too weak.
