DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Mon Feb 19, 2007 1:49 pm
thats what im going to be doing here as soon as my bearings come in. the sohc pistons are in, and im going to be running it on the stock system initially.
i know when we've talked about this before Vinnie had suggested that one should have some 282cc's made out of the 270s from RC engineering for this job.
Bolt on KAs are fairly lean before about 5300rpms. Then its right to about 12.5 to 1. So its before 5300 im worried about, especially with how much leaner everything gets with the intake manifold. Plus we know there is power to be found with jsut fuel tuning.
However, since high compression isnt actually adding more air, its jsut compressing it for more potential, you can get away with out adding more fuel. Granted, at this level of build you already need fuel, so you cant really get away with it.
So its mainly octane you're worried about here. However, ive noticed some high compression Hondas have been running lower octanes to take advantage of the greater power potential of the much faster flame front at higher RPMs. I'm fairly certain you probably wouldnt get away with running any less than 91 without the knock sensor throwing a fit in these cars though
i'm curious to hear anything anyone has to say about their SOHC pistoned DE build
