Yes its the far left screw as you are facing the back window that attaches the seatback to the structure. It is the only one that is weak, the others went out very easy. It started to wear the first time I tried to turn it.maxnix wrote:What screw is this? The ones that hold the seatback to the rear bulkhead?
Shouldn't be a problem unless corroded.
What year is you Q mine is a 1994 and did not have butterflys just standard bodypanel clips.q45_owner wrote:I'll try that. I used the correct size screw driver the first time around and the metal was wearing already(phillips #2). The screw remover was too big and took it out. I posted this thread as I was going through the tangalora how-to and seems like I don't have the 4 butterfly clips holding the seatback to my car either.
Yeah like I posted in Tangalora's thread. Use sockets on the bolts also, not blades.GreenQ45a wrote:What year is you Q mine is a 1994 and did not have butterflys just standard bodypanel clips.
You release them from the trunk (The White ones) with some needle nose plyers.
