Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Tue Oct 12, 2004 4:38 pm
Ok, the swap is about to begin. Now, I see a few people using two BOVs and some people using only one when they are installing the RB26DETT motor.
I am using ONE HKS SSQV BOV for the swap. I already bought a recirculation kit for it and a Y-fitting to convert the single recirculation line into two to vent back into the intakes. I have the HKS BOV located 8-12 inches from the intake manifold, with a weld-on 65mm flange. Isn't this feasible?
I ran over 10-11 pounds on my Turbocharged Maxima just fine with no apparent turbo blow-back (ie no fluttering) on the same BOV, and that being a 3.0 motor. And there are MANY WRXs, EVOs, SRT4s, etc with the same BOV running close to 20 lbs of boost. Am I good to go with this setup?
Thanks guys.
Also, while I am at it. What are those two lines that run off the top of the valve cover that go on the right side of the engine bay that people install aftermarket? All I see in some RB26DETT photos are two large stainless steel braided lines running from the two fittings on top of the valve cover to somewhere on the right side of the engine bay near the front. Thanks.
