need fly wheel torque specs
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
.Please no links to FSMs they never load on my comp. (i might just be retarded)
I have two numbers writen down. One in the high seventys range and the other in the low nintys.
I forget were I got these numbers and would like to know witch is correct before torquening the flywheel.
Please help so I can finally get this beast running!!!!
-Thanks-
Modified by white90esex at 4:41 PM 7/20/2007
gabo
Car: 1992 nissan 240sx
90 ft. pounds
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
thank you.
I like the straight forward answer.
Whats the torque on the clutch to flywheel?
I have here that its 27ish.
gabo
torque all to 15 ft pounds, then go back and torque to 22-27
efrain240sx
Car: 1992 nissan 240sx HB
FSM says 93-101 lb-ft
pearlS13
Car: 90 240sx
^ thats correct. Flywheel to crankshaft spec is 93-101 ft/lbs.clutch to flywheel spec is around 30 ft/lbs...I cant remeber the number to be exact but 30 rings a bell.
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
OK, I had gotten all my stuff torqued on Saturday but havnt had time to bolt up the transmission, gonna do that after work tomarow.
I need to make sure all bolts are tight and do something about transmission wiring and then crank it.
Car should start just fine without transmission wiring correct or is that all required for it to start?
