Need factory service manual for Nissan altima 2020 sv
General discussion area for the L33-chassis Altima.
vishaltuli09
Car: 2020 Nissan Altima SV
Hi I need nissan altima service manual for 2020 nissan where can I get it
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
You have to rent it from Nissan publications. They stopped doing PDF manuals after '16, from '17 up they're only available online in HTML format.
https://www.nissan-techinfo.com/deptsubs.aspx
vishaltuli09
One day subscription $35 is highway robbery! Any other option?
VStar650CL
Technical Expert
Nope. You can save the manuals to PDF files section by section if you rent them, but you'd probably need more than a day and you'd still need to organize them yourself.
vishaltuli09
how about those after market service manual, all I need access to the torque spec for now?
VStar650CL
Technical Expert
The aftermarket manuals are usually pretty good for stuff like specifications, but I'm a Nissan tech, I can get you torque specs if you tell me which ones you need.
vishaltuli09
I need torque specs for brake pads, rotors (front and rear), and Lugnuts
VStar650CL
Technical Expert
Lug nuts are 83 lbs/ft
FRONT: Slider bolts are 20 lbs/ft, frame bolts 133 lbs/ft
REAR: Slider bolts 32 lbs/ft, frame bolts 62 lbs/ft
VStar650CL
Technical Expert
For the rears, that slider value is for a standard parking brake. If you have electric, it's 25 lbs/ft for the sliders.
vishaltuli09
VStar650CL wrote:
Mon Jun 02, 2025 10:28 am
thanks @VStar650CL , I don't see any physical switch for parking brake, I have a button , does that mean i have electric ? Anything else i need to keep in mind while i perform the change
Return to “6th Generation Altima Sedan (2019+)”
