Jim_A_B »
https://forums.nicoclub.com/jim-a-b-u4738.html
Mon Dec 06, 2004 5:23 pm
I replaced my '91 240SX's shocks/struts and I replaced the worn out bushings in the tension control rods with the hard eurothane performance type. I also replaced the tie rod ends. I got an alignment today. The car was pulling hard to the left, but it rolls straight now. The steering wheel was shaking bad at about 50+ mph. Now it shakes, not bad, but more than it should at about 70+ mph. I'm thinking either the wheels need balancing (but I just had them balanced not too long ago) or else something else in the front suspension is worn out. The steering is responsive, but seems a little loose on center (understand?). I'm super cheap, but I want to fix this. Other than getting ANOTHER balance, what else can I do for free (DIY)? What else should I check? I imagine the alignment guy just set everything at factory specs. Should I try increasing toe-in by 1 turn of the tie-rod end? Could the stiff eurothane bushings be messing up the caster?
