EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.html
Fri Jan 05, 2018 1:37 pm
Well, for the head gasket, the sweet-smelling white smoke should also accompany it.
For oil consumption, 2 quarts per month is a little too much... well, depending on how many miles are covered in a typical month. Have you replaced the PCV valves recently? The changes can be dramatic.
I'll try to look at the cooling system layout to see what kind of issues a failed rear thermostat (water control valve, they call it?) would cause.
What would it take to address it though, extra intake gaskets as you take the intake apart for access + a chance to look at the power valve screws?
