Attack_Time wrote:Hey guys, first time member, long time reader.I am looking at purchasing a 1992 Silvia K's with 145 000 km on the SR 20 red top. Is this asking for engine problems? How many KM's do SR 20 Red Tops usually make it to before they need a re-build? Any input would be greatly appreciated!
Thats gonna be a hard question. Most of the guys around here get the motor it self, not preinstalled in a car, and rebuild or at least refreshen the motor.
In your case i would check key things, water pump, front main seal for leaks, rear main ever replacedHow does the clutch feelWhat mods have been done to the car( usually give you an idea on how hard the car was used)Rust
If all those check out you should be fine. These motors can last a while.
