mranlet »
https://forums.nicoclub.com/mranlet-u10142.html
Sun Sep 21, 2003 5:54 pm
Hey all - This is going to be a big message, but please bear with me...
I will soon be starting the ground-up fabrication of a drifting/auto crossing/stuff hauling/drag racing street rod. The frame will be made out of 2"x2"x.1" RHS [Rectangular Hollow Section] steel tubing with double wishbone suspension on all four wheels and pushrod dampening on the front. When finished, the curb weight could range anywhere from 1500-1800lbs with a power-weight ratio of 575+hp/ton depending on ENGINE CHOICE...
For the build I will mosy likely use a swapped-out KA24, but will replace it with a stronger powerplant shortly after.
These are the final motors/layouts I've been considering:-SR20DET RWD-RB20DET AWD (from GTS-Four)-VG30DET RWD-1/2JZ-GT(T)E RWD-RB25DET w/RWD (or to go in with someone wanting a RWD RB26 and swap transmissions so that I can have AWD)
What I really need to know is:1-How much do each of these motors weigh? (My sources put the SR20DET and trans at 490Lbs)2-What are the dimensions (length of block, length of trans, width of combo, height of block, height of trans)?3-Will 2"x2" RHS tubing fit alongside the motor just below the heads, or how much modification would be required?4-Where is the balancing point? (my sources put the balancing point of an SR20DET and trans is around the 3rd cylinder)
NOTE: I'd like to have the availibility of AWD in the future, but it'll most likely be impossible on my current budget. The AWD would preferably need to be disengag-able into RWD (drifting, to compete in more classes of drag/auto-X), so Subaru motors are out (in addition to the $5k price tag of an EJ20 and its too-far-forward balancing point). Cost of getting these motors to 500-600hp is also a consideration, but points 1 and 2 are much higher priority since proper weight distribution is more important to me than raw power.
Obviousally, I'm not expecting people to have answers to ALL of these parameters, but I want to find out as much information as I can so that I may make my decission well-informed.
Any acurate information would be GREATLY appreciated!!!
Thanks in advance!-MR
