Need dyno results to compare with
compression
Heres the setup: S13 redtop, freshly rebuilt. Head work, headgasket, etc. S15 T28 turbo running 8psi, stand alone EMS, 3" exhaust, stock injectors, custom intercooler etc....I am in the process of tuning it on dyno and we are experiencing some weird ignition problems in the upper rpm range (above 3250 RPM). Anyway, I need to see some dyno plots of some RWD SR20DET's at 7 or 8 psi so we can see the shape of the curve and what rough ballpark numbers it should be making. This can help us diagnose the problem and let us know when we are up to reasonable power numbers.
Does anyone have dyno plots of an SR at 7-8 psi to share?
Thanks for the help.
candela
try going to http://www.az240sx.org i think Dave and a few others have stock boost plots..
yellow_jacket
Car: 95 240sx
