ok thanks !! i soaked it with lubrication for bolts and used pbblaster and wd40 lol still wouldnt break loose but i think its because i cant find any bar that will fit the wrench =[gnvarnadore wrote:yeah put your wrench up towards the floor board on the pasinger side and pull down, its going to be hard, might want to wd-40 them bolts and get a pipe to put on the end of the wrench to use it as a breaker bar.
Get a 3/4" breaker bar, an adapter, and an impact socket. Done.pungkiteater_671 wrote:fakkkkkkkkk pissing me off !!! i cant find anything handy to use for a breaker bar none will fit the other end of the open wrench !!! ive tried using a bar and pulling down but it wont break off !! this shet is HARD so far this is hardest part of this swap
i will try this tomorrow lolLoserCard wrote:OMG people, lets make things way more difficult that they should be.
Step one: Get a normal 14mm (or 12mm I can't remember) wrench.Step two: Lift rear end of car and prop with jack stands, or be stupid like me with just a jack on diff.Step three: E-brake.Step four: Put wrench on nut.Step five: WHIP OUT DAT MUTHA F***IN 3lbs SLEDGE HAMMER AND BEAT THE SH*T OUT OF IT! No, seriously though. It takes like 2-3 mild/light hits on the wrench to break it loose. From there it's like butter.Step six: Let off E-brake, turn wheels, repeat Step five.
Sledge hammer is the key. Takes me 10 minutes by myself to drop the driveshaft.
Beat me to it.baron_harkkonen wrote:Easiest way to put it: Lefty loosey, righty tighty. Look AT the head of the bolt, turn left.
thanks guys ... yes i know which one to loosen lolnissanman04 wrote:I hope you are trying to break the nuts loose and not the bolts, because the bolt heads are not able to spin due to the casting on the drive shaft...just making sure, I tried to loosen the bolts before, it didn't work out, haha.
mcgyver ftw240sx_ch08 wrote:Idea I used like once:
Lift up car, put jack stands in, place the wrench and use the jack to turn the wrench for you. Get it positioned and with free hand jack it up.
Only did it once and it worked.
lol ive tried this with other things in my car shiet works ima try all these tips tomorrow thanks guys !!240sx_ch08 wrote:Idea I used like once:
Hizaaaah I winpungkiteater_671 wrote:YESSSS got these f***er off used the jack technique to bust the bolts loose took me like 10 min to take all them off now i have to find sum1 with a picker lol
