Dylan_W_82 wrote:Oh right sorry im trying to replace the main vehicle harness
Are you serious!! The main body harness is very very hard and time consuming to replace. Just about every body panel, engine and dash will have to be removed.
Let's just hope you are confused, and you are actually replacing the engine efi harness that connects to the ecu. If this is the case, here is a color coded diagram. Some of the wires are labelled "rt" for the RHD models:
http://z32.wikispaces.com/ECU+Harness+Diagram
Hope that helps, and let's hope it's the efi harness you are replacing:)
