Grace's ReVersa »
https://forums.nicoclub.com/grace-s-reversa-u124174.html
Sat Jan 10, 2009 5:36 pm
The easiest way to get to the third nut is to take off the windshield wipers and remove the entire front cowl. It sounds like a lot of work , but you can get a straight shot at it. A few posts back someone mentioned going through the plug. That is good option, but if you drop the nut its gone and youll wind up having to take the whole front apart anyways!There should be a series of clips holding the cowl to the top of the firewall. I believe theres about six of them total.Good Luck!
