need custom dp...
sil820
im looking for someone that can help me out.. i need a custom dp and turbo extension... i dont have custom rb motor mounts.. so its using the old motor mounts.. that means it sits a little higher.. and the steering shaft/column or wutever is rubbing the turbo extension.. i have t3/t4 upgrade.. so i still want 2 use the same exhaust manifold.unless its pretty cheap 2 get one made...which i doubt..but i need a dp and that turbo extension.. that will fit that turbine..and not hit me steering column/shaft. thanks
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Hey hit me up.
93RPS13
Car: Cars, Girls, Cars, Food
night has one that has a small bend to clear the steering shaft i think
xjon
Car: 99XJ, 93 240coupe
I'd hit up yellow!
Project240
Night has a custom downpipe, but as far as I know he doesn't sell custom O2 housings to clear the steering shaft. Your best bet would probably be to go to a good exhaust shop and have them fab you one.
Me, I got lucky, my steering shaft has about 1/4" of clearance...
jbanach77
Car: family, fast turbo cars
well are you going to use the skyline crossmember or the 240sx crossmember? and will that make a difference, maybe some of the guys who have done the swap and not had to get a dp made will chime in
sil820
thnx i talked 2 protech there gonna make one for me
ma 180sx
Car: drift, break, fix, repeat
How much did they charge?
sil820
they still gotta look at it.. but over the phone they said under 300 or maybe 300
jbanach77
i had a tubular equal length manifold from them on my gti-r motor. bill knows his stuff. looks great and structurally flawless. they make superb items!!! i would use them again if i ever had the chance
