Need computer help...nerds come quickly.
DrifterXRPS13
Car: 1993 Acura Integra LS, 1998 Nissan 240SX SE 5sp. KA-T,2004 Honda CBR 600RR, 2005 Suzuki GSX-R 600, 2013 Harley Davidson Iron 883, 2014 BMW S1000RR
hey guys...i was gonna post this in the computer forum but as we all know gen chat gets the most traffic.
So i'm at work and for some reason the sound doesn't work. everytime i try to open the volume controls it says that there is no active mixer...now i've tried troubleshooting this thing for about 3 hours yesterday but no luck.
I've tried the services.msc in "run." I've also tried adding drivers via downloads and file transfers from the other computer here but no luck....i was finally able to find the driver and then add it via "add new hardware" from control panel but it comes with an "error 10 code" which means the file is either missing something or something was added to it.
So i have no idea what the hell is going on and we need the volume to work...any help would be appreciated.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
stream p0rn. you know as soon as the anal starts, the speakers will magically work at full blast.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Open your device manager (right click on My Computer, click Manage, the select Device Manager from the tree on the left). Go down to Sound, Video, and Game controllers and see if you have a primary audio device. If you do, you can right click on it and hit properties to access some diagnostic options and you may even be able to update the driver through that dialog.
RobPaulson
Car: 2013 Subaru WRX
- windows xp?
- do you know what your hardware is called? (like the model number of your motherboard and/or sound card?)
- If the above question is unknown, what brand is the computer? (dell, HP, etc etc)
- has it ever worked before?
- when did it stop working?
- did you do anything to change the PC prior to this happening?
- do you have a sound device connection to the output?
(ooo look @ that, 10 moar posts to 3k)
DrifterXRPS13
mod, i tried that yesterday...and no i don't have anything there wasn't there before...
here is what is listed under "sound, video and game controllers"audio codeslegacy audio driverslegacy video capture devicesmedia control devicesvideo codecs
i'm missing the real tek audio driver which i've downloaded but still for some reason doesn't show up unless i go into Control panel>printers and other hardware>add hardware>yes, already have cnnected the hardware>scroll down to add new hardware device> install the hardware that i manually select from a list>sound, video and game controllers>scroll down to the manufacturers where you find "realtek"> and then you find real tek high definition audio version 5.10.0.6029
DrifterXRPS13
rob
windows xp
real tek
it stopped working a few months ago but we didn't need it until now.
nothing to the pc was changed
not sure what you mean, unless your talking about a jack or a speaker out put.
scotttak
Car: 2018 Camaro ZL1
under sound, video, and game controllers in the device manager, it should have realtek high definition audio as one of the devices. if it doesnt, then it is not installed. is your setup a sound card or onboard sound setup?
alphapig
Car: Nissan Altima Coupe S 2.5
DrifterXRPS13 wrote:here is what is listed under "sound, video and game controllers"audio codeslegacy audio driverslegacy video capture devicesmedia control devicesvideo codecs
The legacy audio means that it's a mainboard integrated sound card, I believe.
Try uninstalling every sound driver you have listed, including the codecs.
Reinstall the driver from the manufacturer website.
Go into BIOS and make sure the integrated legacy sound is enabled.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I've always disliked RealTek audio. It's very common on mainstream motherboards, so I've used a lot of computers with it. On my personal machines I usually just pick up a cheap sound blaster to replace it and never look back. Onboard audio generally sucks anyway, but you're not the first person to have device/driver/magically disappearing audio problems with RealTek.
If you can get the company to buy you a $20 soundblaster, do that.
MinisterofDOOM wrote:I've always disliked RealTek audio. It's very common on mainstream motherboards, so I've used a lot of computers with it. On my personal machines I usually just pick up a cheap sound blaster to replace it and never look back. Onboard audio generally sucks anyway, but you're not the first person to have device/driver/magically disappearing audio problems with RealTek.
Indeed. Weak signal, tons of hissing. Onboard audio is the devil.
The best deal out there is a Soundblaster as suggested or a Chaintech AV-710 with a Wolfson DAC. I bought mine for $7 on ebay 7 years ago, but there's one on there right now for $10. Newegg no longer carries it.
DrifterXRPS13
thanks for all the suggestions guy...i'm gonna try and uninstall all the sound crap and then reinstall everything from dell's website...if that doesn't work, i'll get my boss to pony up the $20 bucks or so and get a soundcard.
i'm assuming installing a soudcard is the same as installing memory.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
DrifterXRPS13 wrote:i'm assuming installing a soudcard is the same as installing memory.
There's a little more to it on the software side, but hardware wise, yeah, just stick the card in the PCI slot. Then once you start the computer windows will find the new device and want to install drivers. You can let it try to find them itself, but there will be a disc with drivers, too. Probably step-by-step install instructions as well.
numbnuts240
2011 Ford Focus
2010 Mazda 3
MinisterofDOOM wrote: just stick the card in the PuCI slot.
SHIFT_Z
Car: On 4's
2019 Subaru WRX 6MT
Former:
2014 Chevrolet Cruze 1LT
2006 Nissan Altima SE-R 6MT
1988 Nissan 300ZX 2+2
1985 Nissan 300ZX Turbo
1986 Nissan 300ZX Slicktop
On 2's
2018 Kawasaki Ninja 400 ABS
numbnuts240 wrote: stick. card. slot.
GOT IT!
DrifterXRPS13
boss ordered a soundblaster from amazon..should be here next week sometime..we'll see how it goes.
drksolest
Car: '91 Nissan 240SX coupe
I hope everything works out... I had troubles with my computer yesterday too. AND THE FAKKIN COPY MACHINE... it was right out of "office space"
pc load letter... wtf does that mean!!!!??????
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
DrifterXRPS13 wrote:boss ordered a soundblaster from amazon..should be here next week sometime..we'll see how it goes.
Sweet! I was expecting you to reply with "buy me a soundblaster, are you kidding?!" Should be a simple fix now.
DrifterXRPS13
lol...nah, boss is pretty cool...plus i've known him for almost 20 years...how do you think i still have a job. lol
scotttak
drksolest wrote:pc load letter... wtf does that mean!!!!??????
load letter paper? i think. i work in a copy center and usually that means you need to load letter paper (8.5x11)
drksolest
scotttak wrote:load letter paper? i think. i work in a copy center and usually that means you need to load letter paper (8.5x11)
thnx for the input but it was just a quote from a movie.
scotttak
ive never seen office space, if thats the movie you're referring to. i heard it was good, but never got around to watching it.
DrifterXRPS13
I finally got the creative sound blaster and installed it...i now has sound....it is amazing!....now to watch some hulu.
PoorManQ45
That's interesting.
I've never had an issue with this. I have noticed the issues that you mentioned when the ground body of the minijack isn't making good contact.
Also, a good set of computer speakers with have a bit of gain in the preamp section to make up for computer systems low voltage.
For the best cheap cards check out M-Audio
