Davezilla »
https://forums.nicoclub.com/davezilla-u195464.html
Sat Oct 27, 2012 12:26 am
Did you check the ground circuit for the I.C. Unit in the dizzy? the other 3 readings are good, but there's also the ground circiut that should read .5 volts or less, if you get a reading of more than .5 volts the I.C. unit is bad. The coil's primary side does read out of spec on yours, but unles tehy read as open they should still be able to fire, even tho the spark may be weak, but with the wrong resistance here it could overheat the I.C. unit and cause it to go out. Another symptom of a bad coil would be that it would work intermittantly, meaning it may fire when cold but won't fire at all after it's been run for some time.
I'd also be checking all the wiring connections and relays going into the coils and I.C. unit as a dirty connection somewhere could also be the culprit.
The next step to confirm it's the coils would be if you got a known good one you could borrow from a different car, or if you could take your coils out and wire them into a different car and crank it over to see if they fire at all.
The reason I'm stressing that you should further check the coils before running out and buying anything is mainly beacuse both of them going out at the same time is so unlikely, and normally coils don't just die instantly, but they do die slowly making your car unreliable about starting and the solid state components like the I.C. unit are far more likely to just die instantly leaving the car stranded wherever you turned it off last. I have seen ignition modules in other cars go out slowly and intermittantly where they will start one time and nothing the next time, but eventually start again... again, making for a very unreliable ride at best. The other part about troubleshooting the ignition carefully and thouroughly is that ignition parts can get real expensive real fast and most places won't refund electrical parts. These engines will run off just one coil tho, so if you checked everything else, you can go out and buy one coil to see if it starts and runs, then if that fixes it, you can buy the second one... This might be your best bet right now since you're low on funds and you won't be out too much if the coils aren't the problem. From what I saw in the manual, the only thing that's out of spec right now is the coil's primary resistance, so if you're sure all your electrial connectors and wiring is ok, then I'd say it's safe to buy a coil and see what it does.
