need clarification on exhaust gasket
vis213
k im replacing my turbo for SR T25 right now and so far it looks like i have to take the exhaust manifold off with it to get it off
i read the FAQ and am confused by what to get
Exhaust manifold gasket 14036-D4200 (EXA 1.8, S13 CA18) Four separate pieces
Turbo Manifold gaskets -> head:
14036-D4201 (x2)14036-D4202 (x2)
or does the 4200 consist of the 4201/4202 together?
and is there any way of getting the turbo off without the manifold?
fallen180sx
Car: 90 Sil80
just tell autozone you got a 88 pulsar 1.8, thats what i used and i got the right goods.
vis213
this thing is just kicking me around...how do you get the manifold off without the motor out? i got the top nuts off but the 2 on the turbo side look impossible to get to
OguraPowerTuning
Car: s13, b12, b13 ser
i took my turbo off with out touching the mani. i remember i did have to take something else off though to get to one bolt i cant remember exactly though. its all about having the right tools.
vis213
i tried to take just the turbo off but there was a bolt with what looked like a plate baically on the head so i couldnt turn the bolt at all
NeedCAforS13
Car: CA swapped S13 coupe
those "plates" hold the bolt from turning. You have to bend them up and out of the way to turn the nuts. I would suggest removing the entire manifold, as its 10000000000x easier than trying to pull the turbo alone with the motor in the car
fallen180sx
Car: 90 Sil80
i jacked the motor up by putting a jack on the oil pan, but i used pillow like material in between the jack and the pan so no damage.. and then i got under the car and i got to the bottom bolts very easily.. i did cut some knuckles though due to the tight space.. but it works. use gloves though incase you dont want to draw blood good luck!
vis213
thx for the help, ill try jacking up the motor tmmorow
NeedCAforS13
fallen180sx wrote:i jacked the motor up by putting a jack on the oil pan
I wouldn't recommend jacking up the motor by the oil pan... I would jack it up by the front of the transmission (bellhousing area) as that is alot stronger and won't break or dent, and will still raise the motor up. Make sure you loosen the motor mounts before jacking it up though. I was able to jack mine high enough to remove the oil pan in the car using this method, so it should get the engine plenty high enough
Sean
float_6969
Yea, I was gonna say the same thing. Don't ever jack the car up by the oil pan. It bends way too easy.
skoolymarm
Car: '89 240sx coupe & 91 240sx fastback
how did you get the stupid oil line off the block?(the one with the banjo fitting). Do you need to take off the turbo elbow? Im havin way too much trouble with this to just replace one gasket. stupid ca
float_6969
none of the oil lines are banjo fittings. That is a coolant line, and there are 2 of them.
skoolymarm
nice to know. but what the easiest way to get them off?
float_6969
19mm socket and socket wrench. Perhapse even a regular 19mm wrench? I'm not exactly sure what you mean. I know they are hard to get to, but just un screw them. There isn't any trick to it.
skoolymarm
cool. thanks
fallen180sx
Car: 90 Sil80
lol the pan wasnt damaged so maybe i got lucky then. thanks..
