need ca18det starter bolts and flwheel
BIGSAM06
Car: 1989 240SX COUPE w/ a CA18DET
does anyone has some?
i need a stock ca18det flywheel willing to trade for my lightweight sr20det flywheel.
619-651-0088 or [email protected] thanks guys!
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
I use Datsun 1200 (A12, A14, A15 headbolts) for my CA18 RWD starter motor bolts.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
I do believe you can use the SR flywheel so long as you have a SR starter......
use the search button there is a thread on it somewhere.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
^ You have to use the sr20de 225mm flywheel. The DET one doesn't work with the CA bellhousing. I think you use a s12 ca18et starter with this setup but I cannot remember for sure.
BIGSAM06
ca18detgabby wrote:I do believe you can use the SR flywheel so long as you have a SR starter......
use the search button? right now i am currently running a lightweight SR20DET flywheel, clutch and pressure plate with the CA bell housing humps shaven down for clearance issues, and a hatachi gear reduction starter from an S12 ca18et... it just makes a loud annoying grinding noise when i start it up and sometimes the starter doesn't even grabs the flywheel teeth...
but im thinking it might be the starter bolts that im using and causing the starter not to line up right and the bolts they're from home depot..and if not i might just switch back to the RWD CA18det flywheel/clutch/pressureplate setup
r34 gtr wrote:^ You have to use the sr20de 225mm flywheel. The DET one doesn't work with the CA bellhousing. I think you use a s12 ca18et starter with this setup but I cannot remember for sure.
hey r34 gtr.. my SR20DET works fine with my CA bellhousing you just have to grind down the two humps inside the bellhousing to clear the flywheel
BIGSAM06
does anyone have a stock ca18det flywheel? or starter bolts?
BIGSAM06
STILL NEED A FLYWHEEL ANYONE?
