Need brake help 06 M35x
Sbrodacz
Car: 06 m35x
I am doing my brakes on my 06 infinti m35x. The fronts are done. I am currently working on the rear driver side. I have everything ready to go. Caliper and rotor is off. My problem is I cannot get the new rotor on. At first I thought I had the wrong size but it matches up perfectly with the old one. I tried put the only back on and not it doesn't fit. I cannot figure out what the problem is. The center circle doesn't line up with the center of the axle. It seems like I can adjust it a little but then it won't fit over the top part of the ebrake. What is going on here? Any help would be greatly appreciated. Thank you!
kmiles
Car: 2015 Q70 3.7 AWD - Hermosa Blue
Sold - 2007 M35x
I can only think of two things:
- Is the emergency brake on? Releasing it may help
- I know there is a hole?slot that allows for adjusting the emergency brake - Can you see the adjustment through that hole/slot?
That's all that I can think of. I'm going to do my rear brakes this week.
