need bolt size for drive shaft loop.
Ace 2.0
Car: z32 2+2,1987 CRX si
as the title states,i need to know the bolt size for the D/S carrier loop.i need to put it in but i dont have the bolts so i need to know the size.thank you in advance..>>>>>A.J.
Ace 2.0
bump,come on guys!!!!!!
180fan
Car: 89 fastback
iirc it was an m12x1.25 or was it a 14...
Ace 2.0
thanks alot man.
the bolts that hold it together i figure i can just use anything because the holes are smaller and it needs a nut.
anyone want to confirm this.>>>>>A.J.
180fan
Car: 89 fastback
it threads through. If you need a nut on that bolt, it's too small.
Ace 2.0
any particular place that i could find this size bolt,maybe home depot or lowes?
180fan
Car: 89 fastback
yeah probably. I usually go to a local hardware store that sells stainless bolts unless I can get it relatively cheaply from the dealer.
