Need Body Kit Help ASAP
VTboyinFL
Car: 240sx 1996
I'm buying a body kit tomorrow and if its possible I want to avoid paying a lot to take it to an auto shop. Does anybody have instructions or know a video or can explain to me how i can put it on myself. It's a front bumper, side skirts, and rear valences. Thanks.
allenms240
Car: 1991 Nissan 240SX
just take off whatever bolts are holding te front bumper on. Use mounting take for the side skirts and valences, and if you need a more secure method, use self tapping screws.
VTboyinFL
Car: 240sx 1996
So the front bumper should use the same mounts as the stock one and for the side skirts and valances mounting tape will hold? And what kind?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Most automotive paint stores should have 3M brand double sided tape that's meant for exterior automotive use. Manufacturers use a it in conjunction with fasteners.
As far as the front bumper mounts, most aftermarket manufacturers try to use the factory mounting methods to get the bulk of their bumper to mount and line up. They tend to not use all of the available fasteners, though.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
And prepare for it not to fit correctly and break very easily.
1SickSilvia
Car: 1992 Nissan 240sx vert
mostly what the others said, the new bumper should have these dimples where the factory holes are supposed to be. You most likely have to drill it out. Get a friend or someone to help you hold it and fit it and drill out where it needs the screws to match to the factory holes on the body. Hopefully its a good fitting bumper, the one I bought had to be cut down the midle and we had to add about an inch of fiberglass to strech it to fit. Post pics when you have it installed.
1SickSilvia
VTboyinFL wrote:So the front bumper should use the same mounts as the stock one and for the side skirts and valances mounting tape will hold? And what kind?
Remove the mud flaps in the front, and use the holes to put screws into , for the side skirts
-drill for the back on the inner fender lip.
On the sides under your door , use the double sided tape made by 3m to hold it on
- make sure to clean the area where you put the double sided tape on very well , because it will let go if its dirty or greasy.
VTboyinFL
Car: 240sx 1996
Thanks guys Hopefullly I dont mess anything up, Ill put up pictures of the kit itself when I get it then also after its installed
VTboyinFL
Car: 240sx 1996
Pissed af because i was heading to get the kit and the guy said it had been run over by his neighborhood backing in. Ughh well I guess I can just get new rims and a front lip or something.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
theres your sign
VTboyinFL
Car: 240sx 1996
All worked out better, i painted my stock rims so cars getting closer to being all black
