pete240sx »
https://forums.nicoclub.com/pete240sx-u28673.html
Wed May 11, 2005 11:55 am
I did something very bad (stupid) the other day. I noticed my 240 was bogging down on the way home, so I pulled the wires and saw that #1 cylinder wasn't firing. So I pulled the distributor cap and saw the rotor and cap needed replaced. For some reason I still can't understand, the rotor wouldn't come off. So in trying to get it off, I thought maybe it was some kinda weird rotor thing, and loosened these two bolts and out came the distributor. So I put it back in, not thinking much about it, and then discovered the rotor popped right off. After I got the new rotor and cap on the next day, I discovered the car wouldn't run. After looking over the internet, I discovered why, much to my dismay. So, lesson learned. I've searched this forum and found various threads on distributors, but most were from people who didn't screw up like I have, so other that gleaning what TDC is, I have no idea what to do right now to get this thing running again.
What do I need to do to get this running? I've read where people suggested turning the engine to get the first cylinder al the way compressed, but how do I check this without tearing the engine down? Can I just put a dowel rod into the plug hole and check it at it's highest mark? How do you turn the engine to get TDC; using the ignition and having someone watch?
Any help here is more than appreciated. I really want to get the car running again.
Thanks
