need asap stock ca18det ecu
flatblack240sx
Car: 91 240sx
just got a ca18det the kid told me that the engine ran fine before he pulled it.Come to find out harness was not done and ecu has a fried resister, car cranks but no fuel ecu does not work. willing to trade s13 parts or purchase. anyone have one email. ASAP
yogart900
Car: 1990 240sx
hey i have the same problem what resistor is it? is it R20? do you know what causes this problem? i also think i might need an ecu as well but i would like to test my cas but i'm not sure how to test it. Do you happen to know how?
Modified by yogart900 at 11:12 PM 4/6/2008
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
Without the dropping resistor your injectors are getting to much current and are not firing. the resistor makes it drop to low imped which is what is required by the stock injectors.
it may not be your ECU........just need a resistor.
I would replace that before you go trying to find a ECU as they are nearly impossible to find these days.
some people have tuned SR ECUs to work, but this requires a rom tune(not a huge deal just one extra step) because the ECUs are difficult to find.
if you are going to have to build your own wiring harness TOO, might as well do it right the first time and just go mega squirt and forget all the other non-sense.(wish I had)
yogart900
Car: 1990 240sx
ok so i should just replace the resistor? my ecu worked before for this and the green and red lights came on but i didn't know what the lights meant at the time. i don't have spark though. I've tested the coil packs igniter and checked all ground wires. they are all good. so would this mean its my crank angle sensor?
flatblack240sx
Car: 91 240sx
yes it was the R20 and i have heard that if you use the ka24de maf sensor it can fry it. I found a guy in japan paid $100 and got an new ecu.
ca18detgabby
03 Infiniti G35
flatblack240sx wrote:yes it was the R20 and i have heard that if you use the ka24de maf sensor it can fry it. I found a guy in japan paid $100 and got an new ecu.
for another 40 bucks you could have gone mega squirt and gotten rid of all your issues.
yogart900 wrote:ok so i should just replace the resistor? my ecu worked before for this and the green and red lights came on but i didn't know what the lights meant at the time. i don't have spark though. I've tested the coil packs igniter and checked all ground wires. they are all good. so would this mean its my crank angle sensor?
idk on this one........ I do believe if your coils are good, plugs are good, ignitor is good, and your wires are there...... the last step is grounding and ECU. you sure your ignitor is good? seems to be a common component to go bad or come loose
yogart900
Car: 1990 240sx
yeah i bought a new igniter cause i thought that was it. so i now i have two and they both do the same thing. hmm. really 40 bux more and i could have megasquirt? is it easy to wire up and tune. well im going to get that resistor replaced and then test my cas and if thats not it well... i don't know what to do next.
ca18detgabby
03 Infiniti G35
yogart900 wrote:yeah i bought a new igniter cause i thought that was it. so i now i have two and they both do the same thing. hmm. really 40 bux more and i could have megasquirt? is it easy to wire up and tune. well im going to get that resistor replaced and then test my cas and if thats not it well... i don't know what to do next.
full write up in the stickes........ I cant image it is too difficult. tim did it how hard could it be?
yogart900
Car: 1990 240sx
cool I'll have to look into it. hey thanks for all your help i appreciate it.
