ugadawg »
https://forums.nicoclub.com/ugadawg-u54548.html
Thu Mar 08, 2007 10:16 am
It's kinda hard to help when people can barely understand what you're typing....From what I can gather, your car won't go over 3k rpm. Check the MAF first and make sure there is nothing loose, then go back over everything you've touched and make sure there is no loose wiring or anything unplugged. That would be my advice. Your CEL should be on, so you could get the codes read. Hope that helps you.
