need asap,ca18det motor mount brackets,please help with any info
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
i have the nismo motor mounts,but i need the metal brackets they fit into my motor did not come w/any.or what can i look for as far as compatibility.
splintercell
need some info pleease,ca gurus,putting motor in this week.
Bwana
Car: Denali
I have one of them (pass side I think) laying around, sold the other one...
ca18detdrift
Car: 89 240sx
If i remember correctly you need the brackets from a CA18ET on a 200sx (S12). You'll also need to custom weld a plate on it and make a hole for your nismo mounts .... or use the CA18ET mounts. Hope that helps
splintercell
ca18detdrift wrote:If i remember correctly you need the brackets from a CA18ET on a 200sx (S12). You'll also need to custom weld a plate on it and make a hole for your nismo mounts .... or use the CA18ET mounts. Hope that helps
i have the specific nismo motor mounts,but your saying i can use ca18et metal brackets that bolt to the engine,which hold the nismo urethane mounts?
[email protected]
Car: 1990 Nissan Silvia S13
splintercell wrote:i have the nismo motor mounts,but i need the metal brackets they fit into my motor did not come w/any.or what can i look for as far as compatibility.
Not trying to hijack your thread.
You have Nismo specific CA18DET mounts? I didn't know they had CA mounts, where did you get them?
splintercell
i bought them off ebay,they had 2 sets.try performancenissanparts.com.i think thats who i bought them from.
MegasquirtCA
Car: 240sx
The Nismo CA18DET motor mounts can be purchased at Courtesy Nissan.
As for the engine mount bracket. Yes you can use the SOHC CA18ET or CA20E. I was in your position and researched it. Yes it would work but I didnt want to do it, so I went onto SXOC and got a set from members on their for $90 shipped. Sadly shipping was $45
Here are pictures of a CA18DET that was swapped into a S12.
This is what the S13 Engine Brackets look like.
Passenger Side.
Driver Side.
Modified by MegasquirtCA at 3:14 PM 5/1/2006
float_6969
Those 1st 2 pics are S12 motor mounts and brackets on an S13 subframe with a CA18DET. The problem with the CA18ET brackets is that there isn't aftermarket "stiff" ones that I'm aware one.
splintercell
hey thanks,fellow nico member shipping them to me.he sent me pics,they look the same as the last 2 pics posted for s13
