Densetsu »
https://forums.nicoclub.com/densetsu-u91979.html
Thu Jul 29, 2010 8:58 pm
Haven't heard of any of these problems as common problems with R50s. Could you elaborate on the problems? What's wrong with the fuel pump, for example, and what kind of "shorting out" is going on in the fuse box? Where's the oil seem to be leaking from? Do you do your own work or take it to a garage... and have you done any mods or changed out any parts?
Of the top of my head... the fuel pump relies on the gas for lubrication. If you make it a habit of running the Pathy nearly dry before filling up, over time it'll take it's toll on the fuel pump. Electrical problems can stem from any electrical work that's been done recently, such as a bad install of a remote starter. And oil can come from anywhere... are you applying oil to the gasket on the oil filter, tightening the oil filter properly, and torquing the oil pan bolt good?
If these rare kind of problems are happening on both your Pathfinders, then try and find some common denominator. Same mechanic, same mods, etc.
