joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Wed Dec 27, 2006 5:01 am
The swishing and whistling noise is probably intake noise. This is normal, though I didn't notice it until after I installed a JWT/Z-tube intake. If you don't like this sound, DONT get an aftermarket intake!
When your in gear, and let off the gas, the G's transmission shimmies a bit. The dual mass flywheel is to blame-but this is normal. However, grinding is not normal, and should be looked at if it starts.
Shut the car off with the clutch up, and listen to the sound. Now do it with the clutch down...sound should go away. Flywheel.
