bone_stock_240 »
https://forums.nicoclub.com/bone-stock-240-u55171.html
Fri May 11, 2007 10:28 am
bump. is the obd2 transmission usable or does it have extra/different sensors on it? All of the accessories are the same right? You only need to use the OBD1 manifolds because their is more emissions sensors on the OBD2 motors? would it be wise to swap to the cams from the OBD1 motor, or would that not make a difference? What was it about the OBD1 intake manifold that restricted the power compared to the OBD2 manifold, cuz I mean the obd1 motors have longer duration cams, but make the same power. Any information would be greatly appreciated. searching on this forum sucks when you actually need to find info.
