bertrenolds »
https://forums.nicoclub.com/bertrenolds-u216061.html
Sun Feb 17, 2013 10:02 am
I'm having the same problem with my 2007 nissan murano s, both the AWD and ABS lights are on all the time. I plugged in my odbII code reader and all I am getting for codes is a fulty gas cap. So I am wondering if the speed/abs/awd sensor is going bad would it throw a odb code or do you have to read it using a different tool like a TCU code reader? Or could this be a case of tire noise since the vehicle is due for a tire rotation? The AWD lock is not working, you can't lock it in park and the vehicle now handles badly in snowy conditions, seems like there is no traction or that the traction control is not working very well. Also if I do need to replace the abs sensor how do I know which one is bad? I'm gonna check the conections as soon as I get a chance but it seems like I should just replace them since the vehicle is nearing 100,000 miles.
