josephrm »
https://forums.nicoclub.com/josephrm-u55184.html
Mon May 14, 2007 5:00 pm
Here is the dillema. I am in the process of tearing down my RB20DET. I wasn't planning on replacing the oil pump, but I was going to replace the oil pump gasket and the front crank seal. I haven't been able to remove the crank timing gear. I have used tons of PB Blaster and tons of heat to no avail. I haven't seen a puller that I could get around the gear due to the oil pump housing. I used a torch for what was probably way too long. I am able to get screwdrivers under the gear, but I am getting nowhere. In all of you guys' opinions, do you think I would be okay to just forget about and move on with the build? I think so, but what do I know?
