OnTheRoadAgain »
https://forums.nicoclub.com/ontheroadagain-u77276.html
Sat Sep 29, 2007 3:54 am
My 91 Q45 went in (towed) when wouldn't start. 1st diagnosis was fuel pump, (8 months old) under warranty still, but for parts only.
After repacing the pump, they said it ran, but didn't run right, cut off etc. The fuel pump control module was bad in ADDITION to the pump.
NOW, they are saying the WARRANTEED fuel pump wasn't bad at all, it is the Control Module ONLY.
Here is what happened:About an hour before the car broke down, as I was about to shut off the motor, I heard the pump was humming loudly. This is what it sounded like 8 months earlier which led to the 1st pump failure. I drove home, stopped for a newspaper, when restarted is idled a little low and rough. It was noticeable but I was hoping just some vapor lock or something. Come to think ot it now, this "vapor lock" feeling happened a lot prior to the 1st pump replacement.
At the traffic light, when I stepped on the pedal, it stalled. Felt like no fuel on trying to restart. Towed to shop. Several mechanics came out, tried tapping the tank area with a wrench / hammer while starting. There was no sound coming from the pump when key was turned on.
Sounded like a bad pump to me: 1. no fuel like symptom2. no sound from pump w/ key on3. loud humming earlier that night.
QUESTION:1. they originally said the new pump DID get the car running, though poorly.
2. Did the warranteed pump do damage to the Control module?3. does it even sound possible that the "warranteed" pump is now ok?4. are they responsible for the latent damage to the control module?
This is a large regional auto repair center, and to say I'm unhappy with having to pay labor $275 to replace THEIR bad pump in only 8 months is an understatement. NOW, they are telling me the control module is $575, and their pump is ok? Seems to me that THEIR pump took out MY control module?
1. DOES THE CONTROL MODULE GO BAD WITHOUT THE PUMP GOING BAD?2. DOES IT SOUND LIKE THE PUMP WENT BAD? (humming, no sound when key on, and the fact that it started AFTER it was replaced?)
Thanks for any help, I've read everything I could about the pumps and modules, but need some qualified opinions.
Modified by OnTheRoadAgain at 7:09 AM 9/29/2007
Modified by OnTheRoadAgain at 8:30 AM 9/29/2007
