Need an answer ASAP!!! About Oil lines for the Oem S15 Turbo
newdude1
On here http://www.frsport.com/FR-Earl....htmlI have the s14 sr, do I get lines for an s14 or s15 because Im going to be running the S15 Turbo?
newdude1
I know someone on here knows this.
goalguy02
Car: '92 240
I believe the only difference would be the oil restrictor and the oil return line. Since you are using the s15 style turbo, go with the s15 style lines.
My S13 redtop with 2871r is using s15 lines. The other thing is make sure if you are using an s15 turbo, you get the s15 oil return tube and hose.
newdude1
They arent the same from the s14sr and the s15?
