loystock »
https://forums.nicoclub.com/loystock-u10145.html
Fri Dec 31, 2010 3:50 pm
Replacing an engine is always expensive, used or otherwise. Looks like you didn't have an overheat nor major oil leak. Given your financial situation, do it only as a last resort. Better do some basic diagnostic as recommended by 'tiger.' It could be as simple as busted fuse, clogged fuel filter, failed fuel pump or dead alternator.
Check oil level is correct. Check for presence of transmission fluid (normal level is only attained if the engine is running and warm). Check the battery voltage, must be >12.5VDC to indicate a fully charged battery. The fuel pump is located in the tank, accessible behind the rear seat. Switch Ignition to ON (not START) and listen if the pump hums (runs) for @ 5 seconds (auto shutdown after 5 seconds). If not, maybe busted fuse or failed pump. If the pump runs yet the car won't start, could be due to clogged fuel filter (located at firewall, besides brake booster) or electrical issue.
Does the engine crank when you attempt to start it? A partially charged battery and/or dirty connections can cause starting problem. Make sure the battery connections are clean and secure and you don't have corrosion on the cables. If the voltage is is 12VDC or less, the battery is technically dead and is useless for starting. If the battery voltage is low and the connections are good, most like a 'dead' alternator. Try to jump start the car and see if it runs. If the car runs and dies once the jumpstart cables are removed, most likely a dead alternator.
