1991S13 »
https://forums.nicoclub.com/1991s13-u22320.html
Sat Aug 06, 2005 6:24 pm
When you pull it out open it up and check the reed inside. If it is all carboned up, that may have been your problem. If it is clean, there is probably something else wrong. Don't stop at plugs, fuel filter and AIV - check out the plug wires, o2 sensor, MAF, injectors, and the list goes on...
There is a sticky in the Nissan Online Mechanic forum that has a list of popular problems, check that out and maybe that can help you some more. Never hurts to seafoam the engine either.
