nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Sun Jul 15, 2007 11:51 am
Check the common issues sticky at the top of the page. That's going to tell you all the common issues.
Additionally, the grounding on B15s is utterly awful, so the battery terminals often get covered with corrosion very quickly and that can cause it to act like it has a dead battery.
Stick to the Spec V. The extra gear and, more importantly, helical limited slip are nice to have. Specs of that time had the same slalom speed as WRXs. It won't drive like the Si or Del Sol practically at all, as the engine is set up for torque moreso than top end.
