evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Oct 02, 2006 6:29 pm
I have bought 3 280ZXT's for about $300 each, they were all auto's, $4-500 if it's a 5 speed will add 1-200 to that, in parts if you have the patience, you can sell $500-1000 depending on the condition of the parts, as for the engine, the cylinder head is more valuable than the block, from my experience fro good parts you can expectthe P90 heads go for about $150 the blocks generally only about $50the turbo oil pan is worth about $30the turbo if in good condition will bring about $100, half that if it's got shaft play 240mm flywheel $30the exhaust manifold will bring another $50intake with good injectors $50the dist by itself is worth $50-75 if workingand the ignitor will bring about $20harness $50-75ECU $50
if the car isn't running and you don't know the condition of the parts they prices go way down, also trim bits can add up but the turbo parts seem to be the most popular and easy to move, the wheels only go for about $100-150 for the set and the T-tops only have a value if you can find someone in need of one, I have only managed toever sell 2 and one went for $50 and the other for $20, a working digital dash can bring up to $100 and many other parts have value if you can find the buyers, and at current steel prices you can sell the shell to a scrap yard for about $100
