johnparkyourcar »
https://forums.nicoclub.com/johnparkyourcar-u70598.html
Tue Apr 06, 2010 8:39 pm
If you're on stock suspension, i wouldn't worry about rubbing issues. If you want wider, why not 255 or even 265? As long as the offsets are on the aggressive side it should be fine. As for the wheels, I have pretty expensive taste, so I can't help you out there. I can tell you that my next set of wheels will be Work Varianza T1S. TOO EXPENSIVE.............
