Looneybomber »
https://forums.nicoclub.com/looneybomber-u14304.html
Thu Sep 21, 2006 10:29 pm
Here is something to think about. If your sub has dual 4ohm VC's, then getting a monoblock amp will be fine. If it is a single 4ohm VC, then get a regular 2 channel amp. Reason being, you can wire the 2 VC's in parallel to get a 2 ohm load. Feed that to a single channel amp and you're in business. If you only have 1, 4ohm VC, get a 2 channel amp, bridge it and now each channel is at 2 ohms.
The reason you want to give the amp a 2 ohm load is because you will, theoretically, double your output. More bang for your buck! If you bridge an amp to a 2 ohm load, each channel will operate at 1ohm. That is ok if your amp is 1ohm stable, but if it's not, you will burn it up.
