s14inwashington wrote:hey everyone I have a few questions. I am currently an ASE certified mechanic at a local speedshop, and i recently sold my civic for a 96 240 SE. At my shop, we have done 2 turbo'd KA's and 1 DET swap into S14's. I read over the forums and im not sure what would be the best setup. I plan to run an entirely stock engine with a turbocharger that utilizes an internal wastegate. I only want to run maybe 7 to 10 lb at the most. So far, i have collected an apexi gt spec intercooler, misc. mandrel bent charge piping, oem injectors off of a S15 DET, Greddy E manage and Profec E-01, and walbro 255lph fuel pump. I would like any advice as to what else to add to the engine to make sure i dont cause nay type of failure. I also have SPEC clutch . I would also like to know where i could acquire a turbo manifold, regardless of what type of turbo it is for, other than revhard. bad luck with revhard cracking. any input would be appreciated. keep in mind- i dont want to take this motor apart.. i have done two and timing chains are a *****....If i pop this motor ill swap in a newbie, all stock again. oh yeah... should the oem MAF go before the inlet on the compressor side of the turbo or in the charge piping?
Revhards can be quite reliable if you prep them correctly. Just separate the flange so that there is one flange per port and drill the holes for the studs from the head to allow for expansion and cracking should not be an issue.
As far as the MAF, it should work in either position as long as flow is smooth in and out of it. The Nissan MAF's tend to be sensitive to turbulence. You don't want it too close to the compressor. And if you are venting BOV back into the intake, make sure it is far enough away from the MAF and angled with the intake stream to avoid disrupting flow too much.
