xyoufailmex »
https://forums.nicoclub.com/xyoufailmex-u25588.html
Tue Mar 15, 2005 11:25 am
I would contemplate a S13 silvia conversion if you really are wanting something unique, or with all the conversions out, you can find stock body panels cheap. I wouldnt advise doing the S15 conversion, simply because i noticed while doing my S13 conversion that if you over tighten something, or get something a little off, nothing fits right... and thats a straight bolt on, everything supposed to line up sort of deal. So, if the frame is shifted and not noticeably broke, it would be nearly impossible for you to fit a S15 conversion on it... you could spend days on end trying to get everything lined up, only to find out your frame IS bent... Fact is... 600 bucks for a 240 is worth purchasing... Id definetily do it.
