s13passion »
https://forums.nicoclub.com/s13passion-u49246.html
Sat May 19, 2007 11:18 am
Okay this has been an ongoing problem and after trying a few things and checking others it's still happening.
I have an SR20DET with basic mods. I've replaced the coolant temp sensor, 02 sensor, plugs, adjusted timing, fuel pump ( walbro 255 ) checked injectors they're still good, cleaned my MAF, IACV. Probably more but can't think of it.
The car runs fine seems to have no problems at first. After about 15-20 minutes of semi-hard driving ( i do this so i can duplicate the problem when i'm trying to troubleshoot ) the car begins to stutter at the 3-4k RPM range. Its only slight at first, but gradually after a few minutes it gets worse and worse. Until from a stop, I have to shift around 2k rpm or give it more throttle in which it responds with stuttering and eventually some backfire. The car will shake and and bog/stutter. I'm guessing its flooding out somehow, as it smells like unburnt and just generally has the symptoms.
Would love some more ideas about this, as it only happens after driving a little and warming up, makes it harder to find.
Thanks fellas lemme know if you come up with anything.
