WingsNThangs »
https://forums.nicoclub.com/wingsnthangs-u6018.html
Sat Nov 01, 2003 11:28 am
ProKit rides better for daily drivers, as the spring rate isnt as high as Sportline springs. ProKits are more forgiving to bumps.
ProKits hardly lower the car at all; at max, 1". If this bothers you, get Sportlines. I've never had sportlines, but I've never heard of any complaints about them other than they dont lower enough (Sportlines lower roughly twice as much as ProKit).
In any case, you should get aftermarket shocks accomodate for the different springs. If you must use your stock shocks with Eibach springs, I highly recommend you use ProKit springs, as the spring rate is closer to stock. But if you know whats good for your car, you will get aftermarket shocks, such as Koni, Tokico, or KYB.
