Need advice on what to buy (tires)
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
guru_ck
Hi All - I have a 2008 Infiniti G37 Sport with about 21,000 miles. The factory Bridgestones are at about the end of their life. I priced some new ones but they came out around $1,000. I'd like to spend a few hundred less than that if possible.
The look and feel of the tires are important to me and I will not spend less to compromise in that area. I'd like the replacement tires to fill up the wheel well nicely like my factory tires do. I'm willing to go for a bigger tire if it won't compromise handling. I also want them to last a while so a treadwear higher than the factory 140 is a requirement.
My factory sizes:225/45WR19 245/40WR19
Your recommendations are appreciated!
biggie
Only thing I saw for a matching set is:Bridgestone Potenza RE760 Sport
Which are almost the same as the OEM ones, like $100 cheaper for a set maybe.
Seems that 225/45/19 is a hard size to find.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
run a different size tire. 225 is a bit small for a 8.5" wheel to begin with. go with a 245/40 up front and 265/35 in the back.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
