MaximA32 »
Mon Mar 01, 2010 7:26 am
At that mileage, MoD is right, something else entirely is wrong. I've got an 04 SE with 124k on the clock and I still get 25 on the freeway. Give everything the once over. Set your tire pressure to the correct setting, make sure your air filter isn't clogged and run some Gumout Fuel System Cleaner through a full tank. See where that gets ya. If your check engine light is on, something is up with fuel delivery or emissions that's causing the car to dump fuel. Does it smell like gas when it's running?
