mahmudb wrote:I'm going to be purchasing new tires in about a month or two and was looking at different options. The 2 tires that I have narrowed it down to are the Kumho Ecsta ASX and the Yokohama Avid W4S. I'm looking for a tire that has good tire wear and is good in light snow and rain. I got an estimate for the Yokohama for $178 a piece with installation. Which one would you recommend? TIA!
I do not have any personal experiences with either of those tires, so cannot comment on that per se.
But, whatever you do end up doing, please keep the following in mind:
1. The load index rating of the tire you pick must be at 95 or higher. In this regard, Michelin is conservative and just about everybody else is not as conservative. So, if you pick somebody other than Michelin, get the highest rating you can. For example, with my favorite tire (the Goodyear Eagle F1 GS-D3), I get 100W rating tires.
Yes, this is being conservative, but I'd rather be safe than have internal tire structure damage with miles. Even if this does not have catastrophic consequences, it usually means that the tires need rebalancing more often, they get out of round in a hurry, you get more tire noise, etc., etc., etc. Just not a good thing to have to deal with.
2. Like mentioned in a previous post in this thread, high-performance summer tires simply will not be safe in cold weather - near or below freezing - regardless of whether there is any light snow on the ground or not. The rubber freezes, the tires get rock-hard and these tires will slide on light gravel or light snow or wet weather ... EASILY ... with a powerful car like our M's.
So, my approach would be (a) get a second set of cheap wheels with snow tires for winter use (best) or (b) a set of A/S tires ... as long as you are only in light snow (second-best). If I lived in snow belt areas, the decision to get a second set of wheels with snow tires would be an easy one!
3. Keep in mind that A/S tires are always a compromise - they are neither as good in summer as "Summer" tires, nor as good in snow as "Snow" tires. As long as you are willing to accept those limitations, then an A/S tire is okay to get.
For example, I have been using Goodyear Eagle F1 GS-D3 tires on my 2003 M45 (in a 245/45-18 100W size) and recently decided to try the Michelin Pilot Sport A/S (in a 245/45-18 96Y size) because I needed to do some driving to Lake Tahoe for a skiing trip.
Yes, the Michelin's were okay in the Lake Tahoe light snow - and I am glad I had them instead of the Eagles - but I can heartily assure you that I am going to go back to high-performance summer tires when these wear out! These Pilot Sport A/S tires simply do not have the handling, tracking, or wet weather braking, that I am used to with the Eagles.
Totally perceptible performance differences - uphill curves near my house that I felt comfortable (albeit on the edge) taking at 80+ mph on my Goodyear Eagles (or with Firestone Firehawk SZ-50EP ... no longer made ) are now taken at 65+ mph, with more sense of drama.
Z
