If you're saying it LASTS 30 seconds... then it might be what I had. I had a loud ugly noise that sounded like metal grinding on metal and it lasted for 30 seconds. It was a broken heat shield bracket and everything was replaced and now it doesn't make that noise.opekone_1988 wrote:Good day mates, I know that this issue has been reported previously but I was wondering if anyone has any specifics that I should point out before I go to the dealer shop for repair. Symptoms: I get a weird clanking noise on cold start-ups and last like 30 seconds and then goes away, but only on cold start ups though. I've heard many theories from ECU problems, loose heat shield and dead hamster caught on belt..j/k.. seriously though, any input would be greatly appreciated.
I think I might have this. I have some very loud noise upon starting the car (in Parking) but once I shift to Drive or Reverse, the noise goes away. Any idea on what this can be?BlackNWhite wrote:If you're saying it LASTS 30 seconds... then it might be what I had. I had a loud ugly noise that sounded like metal grinding on metal and it lasted for 30 seconds. It was a broken heat shield bracket and everything was replaced and now it doesn't make that noise.
If it only happens once on a cold start, it's probably the ABS check. It'll usually occur within the first 15-20 feet of driving after a long sit. It feels like a clunk, right? That's normal.aahx489 wrote:Hi LinkNuc,
I've been looking for something similar to what you explained. When i do a cold start, once i put the car in reverse or in drive, it seems after it does a full tire rotation or a little more, i here a popping noise coming from the front. This is the 4th time i heard this after a cold start. If i drive around and shut the car off and then turn it on and move, i dont here that pop. it sounds like something is loosening up because it was stuck or something.. you mentioned in this post that it may be because the ABS? Can you please give some more details and is this something that is covered under warranty or could be a potential disaster or big problem?
Every time I took it to them they said nothing was wrong. So what I did was I left my car overnight so it could get a cold soak and I got there at 8 in the morning and had the service advisor bring over a tech and had them both listen to me turn the car on.opekone_1988 wrote:Same here as last post, as soon as i shift to drive or reverse it goes away but as i'm starting up while on parking its this loud nasty noise and doubt that its normal, too loud to be ABS or any of that sort, but like i said' it last about half a minute and then goes away but only on cold starts so a loose heat shield doesnt make sense because i doubt the heat shield gets tighter as the car warms up... dunno' just my analysis. I just dont want to go back to th dealer and then they tell me that nothing is wrong when obviously there is.
So what was wrong? Did you find out yet?BlackNWhite wrote:Every time I took it to them they said nothing was wrong. So what I did was I left my car overnight so it could get a cold soak and I got there at 8 in the morning and had the service advisor bring over a tech and had them both listen to me turn the car on.
Suddenly... there was a problem with my car.
My pardons.. you are absolutely right. This weekend I decided to check it out myself and opened up the hood and started the car, to my dismay the freaking Heat shield was rattling like crazy (You can clearly see it) and once the car cooled into a complete idle it stopped rattling. I turned off the car and once it cooled a bit I was able to check the heat shield with my hand it the thing was loose as hell. Didn't have time to tightened it but as BlackNWhite stated, if the bracket is broken then the dealer needs to replace it. Thanks for the info.BlackNWhite wrote:If you're saying it LASTS 30 seconds... then it might be what I had. I had a loud ugly noise that sounded like metal grinding on metal and it lasted for 30 seconds. It was a broken heat shield bracket and everything was replaced and now it doesn't make that noise.
Haha, glad I was of help.opekone_1988 wrote:My pardons.. you are absolutely right. This weekend I decided to check it out myself and opened up the hood and started the car, to my dismay the freaking Heat shield was rattling like crazy (You can clearly see it) and once the car cooled into a complete idle it stopped rattling. I turned off the car and once it cooled a bit I was able to check the heat shield with my hand it the thing was loose as hell. Didn't have time to tightened it but as BlackNWhite stated, if the bracket is broken then the dealer needs to replace it. Thanks for the info.
Yup, if you rev the engine a but it will go away or if you shift to anything else but P it will also go away. You can check it out by opening your hood, starting the car and look down the exhaust pipe in the front right in between the radiator and engine and you can clearly see the heat shield rattling. I’m gonna try fixing it myself this weekend along with installing HID's and Intake.. I'll let you know of the heatshield bracket is just loose or broken. If its broken then I’ll have to go to the dealer and get it replaced.SHIFT_2.5S wrote:I once again noticed the loud noise today on a cold start. However, if I shift from P to anything (reverse for instance), and then go back to Parking, the noise goes away? Is this the heat shield?
Thanks for the heads up. Is it possible for me to tighten the heat shield myself, or do I have to take it in?opekone_1988 wrote:
The link doesn't work.bradz wrote:I just found out the noise in my A/C. It was coming from the heat shield bracket. I just put some metal wire around the screws and tighten it and no more annoying noise. BLACKNWHITE was right. Here is the link for that F***** heat shield that keeps me worrying for a long months...
http://i15.photobucket.com/alb...7.jpg
