need advice on SR20 Swap
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
well i'm planning on ordering a motor/extra stuff for my S14 this week and here's my list so far
-S14 SR20DET-FMIC kit w/ piping (probably greddy)-heavy throttle hotpipe w/ greddy bov -heavy throttle 3" downpipe-K&N popcharger-walbro Hi-Flow fuel pump (255lph)-SVR Slim Battery-Spec Stg. 1 clutch-heavy throttle harness ($300) seems like it's worth it-boost gauge-Apex'i AVC-R ?? not sure if it is what i want-Denso 550 injectors-Greddy Exhaust -J30 VLSD
here are my questions...1. in regards to the AVC-R, i want somethin that can take advantage of the larger injectors, and also up boost to around 12 psi. the AVC-R can do this, right?
2. are the 550 injectors even needed on the stock turbo? i figure the injectors would let me run 12 psi safely...
3. i dont want to bother with a ECU adjustment yet, so i was wondering if the AVC will do, or if i need something else
4. instead of the greddy exhaust, could i just have a custom one welded up using a real Greddy muffler? or would that be not as good?
5. am i missing anything? what do you think of my list? change it if you think it should be...
i'm looking in specific for what the real shop guys have to say about this, as well as anyone else that is educated in this area.
MainEvent212
come on guys...there are like 40 people online right now
MainEvent212
no love...
S13 SR20DET redtop 2500FMIC kit 799BOV kit 2993" downpipe 159K&N popcharger 55Walbro Fuel Pump 119SVR Slim Battery 109Spec Stg 1 Clutch 299Harness Wiring 300Boost Gauge 64Apex'I N1 Single 415Apex'I S-AFC 339NISMO motor mounts 275DNA boost controller 95
well this is my new list...i figure i can cut alot of costs w/ the S13 redtop instead...and i dont think the power difference will be all that much...anyways, i'll probably have a new turbo w/in a year
these are all heavy throttle prices so far...if anyoen can help me out, please do
NeedCAforS13
Car: CA swapped S13 coupe
t25 vs. t28... whats the difference in price (I know nothing about SR's... silly aluminum motors;))
Sean
SideWays Silvia
Car: Drifting, Tuning
well u wont have to upgrade the ECU yet since you are going to get the Apexi S-AFC. you can do all the tuning you need for right now off of that.
NeedCAforS13
safc= band-ade
ecu reprogram= proper solution
but for such little upgrades, SAFC might be a better investment?
Sean
SideWays Silvia
yeah, like sean said, that is the main diffrence between S14 and S13. bigger turbo and S14 has a VTC unlike the S14. so there might be a bigger power diffrence than you thought
MainEvent212
well from what i hear, the power difference is about 10 whp...which is, for 1000 dollars difference, perfectly fine with me.
what i would like to know though, is where else can i shave costs?
NeedCAforS13
$12 mbc? instead of a $90 one...
or run stock mounts for awhile?
or even run stock sidemount for awhile (with low boost!) :eek:
Sean
MainEvent212
$12? how
also, would it be awful to run stock mounts? i just figured i might as well put in new mounts while i'm down there...
no way i'm running an SMIC lol
NeedCAforS13
http://cgi.ebay.com/ebaymotors...33742
I haven't used them myself, so I know nothing about quality... but I've heard they work decent for a manual boost controller:)
if your stock mounts are in good condition, then I would use them...
and side mount isn't THAT bad (temporarily at least), its just not bling;)
Sean
NeedCAforS13
oh and Enjuku's wiring service is cheaper than $300 if I remember correctly... email them to find out how much:)
they also have your slim battery for $99
http://www.sr20detperformance.com/
Sean
Phax
Car: Control dynamics
NeedCAforS13 wrote:and side mount isn't THAT bad (temporarily at least), its just not bling;)
:Werd
I'm running the SMIC right now and the car is still fun to drive. Even at stock boost, the car has more than enough power to get you quickly pulled over.
If you're serious about saving money right now, then hold off on the FMIC until you get a turbo upgrade.
MainEvent212
ok so i think i have my list pretty much set in stone...
but where to go for harness service? who is the best?
NeedCAforS13
I had mine done by enjuku... HIGHLY RECOMMEND THEM!:D
Sean
MainEvent212
ah, good, that's what i was lookin for lol
and the slim battery is necessary for an FMIC correct?
deftdrummer
Car: cars, drums, music, technology
enjuku or heavy throttle. I believe enjuku is a little cheaper, they definitely know what they are doing though and they need your original harness too Btw
proimport17
Car: motocross, baseball
Dont think Enjuku is doing harness conversions anymore.
NeedCAforS13
I'll have a link for you in an hour or so... but, you are correct "enjuku" is not doing harnesses anymore, they send it out to the former employee who used to do them there at Enjuku... he is now doing just SR harnesses... he is a student and has no time to work at the shop anymore, so he just does their harnesses...
like I said, he's finishing up his website, and I will link it later tonight when he has it up and running!:)
Sean
MainEvent212
awesome...is there anything else that i might need to be thinknig about?
proimport17
the guys name is esteban. He has my harness right now. He seems to know what he is talking about.
NeedCAforS13
Estevan, and yes! he did my harness too, and he's the MAN!:D unfortunatly I've been to busy to call him to get the link to his webpage... let me go see if I can get a hold of him now:)
Sean
